Publishing mxd file that contains mosaic has a problem,
2398
05-21-2014 10:24 PM
JamalNUMAN
Legendary Contributor
I wanted to publish mxd file that has one mosaic and one feature class.
[ATTACH=CONFIG]33995[/ATTACH]
It is published successful but as the service is added to the ArcMap and a zoom is applied (for example 1:1000), the mosaic disappears and produces black\white cells.
[ATTACH=CONFIG]33996[/ATTACH]
At scale 1:200,000, the service is displayed properly
[ATTACH=CONFIG]33997[/ATTACH]
What might be the issue here?
Thank you
Best
Jamal Numan
George_Thompson
Esri Notable Contributor
Jamal,
Have you built pyramids and statistics on the mosaic dataset?
Mosaic dataset overviews: http://resources.arcgis.com/en/help/main/10.2/index.html#//009t00000040000000
It looks like the data is not available for that scale range.
Here are other forum post that seems similar:
http://forums.arcgis.com/threads/104638-Problem-displaying-Mosaic-datasett?highlight=squares+image
http://forums.arcgis.com/threads/104664-Mosaic-photos-not-visible-until-zoomed-in-real-close?highlig...
--- George T.
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
Jamal,
I�??m not sure if this issue is related to image type.
I converted the ecw images to jpg and all works fine. The Mosaic and its service are successfully created.
[ATTACH=CONFIG]34289[/ATTACH]
JamalNUMAN
The screenshots in the first post here disappears due to upgrade! How can they be recovered?
Thomas Edghill
Jamal Numan
MichelleMathias
Esri Community Manager
Hi Jamal, unfortunately we don't have a way to recover old images from a post. We haven not had a recent upgrade so I am not sure what may have caused them to disappear. I will post the question to our vendor support team for further investigation.
Michelle Mathias
Manager, Community Experience & Programs
