I have an arcgis server installed on a Windows 7 machine, it is already using https, but without a valid certificate.
To configure WebAdaptor, use the https server link https://myhost:6443 and after configuration do not access the web adapter with https, only http. Now via webadaptor, go to http://myhost/arcgis/manager.
Without using webadaptor or https it works perfectly.
Why is this happening?
Solved! Go to Solution.
Hi Sorato Marques,
In most situation this could just be that the IIS Server is not enabled for the binding on port 443 (HTTPS) hence the site will work only with http. Other situations, there could be a mix protocol both on IIS (http binding port 80 enabled but not port 443, could be happening in your situation) and ArcGIS Server (http and https enabled or just http only enabled, like on pre ArcGIS Server 10.4, which could be in this case)
Again depending on the version of Arcgis for Server, you may want to see the default protocol that the Arcgis Server is configured with.
Enable HTTPS on your web server—ArcGIS Web Adaptor (IIS) Installation Guide | ArcGIS Enterprise (10.7 document)
Enabling SSL on ArcGIS Server—Documentation (10.3 and 10.3.1) | ArcGIS Enterprise (10.3 document)
Hope this helps.
Hello Sorato Marques,
Just to confirm if you try to access ArcGIS Server manager over 'HTTPS' using your web adaptor does the page fail to load?
Example URL: https://hostname.domain.com/webadaptorname/manager
If you sign into the ArcGIS Server admin endpoint what URL is listed for the web adaptor?
If you open the web adaptor configuration page click on server and click next. What URL is listed to access the service directory?
Finally this problem may be caused by the invalid certificate. I would recommend configuring a valid certificate with ArcGIS Web Adaptor and ArcGIS Server.
Hope these suggestions are helpful.
Thomas.
"Windows 7, 8.1, and 10 are supported for basic testing and application development use only. They are not recommended for deployment in a production environment." ArcGIS Web Adaptor 10.7.x system requirements—ArcGIS Enterprise system requirements | Documentation ...
That might be your problem. Running IIS on Win 7, or even 10, introduces all sorts of flaky instabilities.
If you can't reach the IIS splash page via HTTPS, (https://myhost), then the problem is not with the web adaptor or Server, but the IIS instance.
Hi Sorato Marques,
Hope this helps.
