PrintingTools GP Service missing tasks after upgrade to ArcGIS Server 10.6
3172
11
01-26-2018 02:19 PM
JoelBrown
New Contributor II
I just upgraded from ArcGIS Server 10.2 to 10.6.  After the upgrade the default Utilities/PrintingTools GP Service does not have any tasks listed (see attached screen shot).  I believe this service should have a "Export Web Map Task" and a "Get Layout Templates Info Task."   Does anyone have any idea on what happened and/or how i can resolve this issue?  Thanks.
TanuHoque
let's see whether this helps:
- delete the service using Manager/Admin side
- create a new one following instructions from How To: Restore the default PrintingTools service in ArcGIS Server Manager  using the json from 10.6 section
TanuHoque
Joel,
Could you pls contact Esri Support and have someone take a look at this? It is hard to say what is going on without looking at the server/service settings etc.
thanks.
JoelBrown
New Contributor II
Thanks for the quick response.  I'll try and get a support ticket rolling but in the mean time i would like to troubleshoot here if possible.  Please let me know what server/service settings you are interested in.  I believe the printing tools GP service is the default service that came installed out of the box when we originally installed AGS 10.2. Thanks.
JoelBrown
New Contributor II
Quick update.  I just tried creating a new print service using the instructions in the link below.  The new print service was also created with no tasks.
MatthewDowning2
New Contributor III
Hi Joel - did you ever resolve this issue? I also recently updated to 10.6 and am experiencing the same issue.
JoelBrown
New Contributor II
No.  I have not resolved the issue.  Hoping someone from ESRI can chime in with something beyond "call support."
TanuHoque
Joshua-Young
Occasional Contributor III
Thank you. These steps fixed the issue for me. The default print service now has its items under Tasks again. We upgraded from 10.5.1 to 10.6 and the Tasks were missing.
"Not all those who wander are lost" ~ Tolkien
JoelBrown
New Contributor II
Thank you.  I actually linked to that document in an earlier comment but i see that you have now added instructions specifically for AGS 10.6.  The updated instructions do indeed work.
by Anonymous User
Not applicable
This happened to me upgrading from 10.5.1 to 10.6.1 and these steps worked! Thank you!
