Permission error configuring arcgis data store 10.6.1
7670
12
07-25-2018 04:09 AM
EinarDørheim1
Hi
I had arcgis enterprise 10.6 installed on my computer, single machine setup, basic settings, installed with Enterprise builder. Configured Datastore for Relational and Tile Cache. I tried to upgrade my enterprise to 10.6.1 and ran into some troubles.
Firstly the enterprise builder for 10.6.1 ran through and upgraded my applications, telling me everything was OK and upgraded except my Portal. So to fix this i downloaded the setup file for  Portal for acrgis, installed it and configured the web-adaptor. So far so good. I can log in to both the portal and the federated server.
However, I noticed that none of my hosted feature layers didn't work, and that I got a red exclamation point when trying to validate the server/data stores.
So I tried to run the Arcgis Data Store Configuration Wizard and run in to this little error message:
Runtime error detected on one or more operation on the configuration store, with message:'{0}'.. Extended error message: Failed to get file permission
Which suggest the user doesn't have the right permissions, so I gave admin user account full priveliges for the following directories(included subdirectories) : C:\arcgis\arcgisdatastore, C:\arcgis\arcgisportal, C:\arcgis\arcgisserver,  C:\inetpub\wwwroot\portal, C:\inetpub\wwwroot\server, C:\Program Files\ArcGIS (subdirectories: DataStore, Portal, Pro, Server) and C:\python27. Basically every directory related to the enterprise.
When trying to validate the Data Store through the ArcGIS Server Administrator Directory with
Relational data store: data > items > enterpriseDatabases > <data store name> >machines > <machine name> > validate
I get this message: Server machine 'https://(Machine.Name):2443/arcgis/datastoreadmin/machines/PC-(Machine.Name)/validate' returned an error. 'Data store hasnt been created on this machine.'
Get Error msg 404 unable to get ...:2443/arcgis/help/nb/cxhelp.xml
Have tried to run a repair on the Data Store installation - no success.
Have tried with running the config wizard for datastor with both localhost url and url with machine name, results in same error message.
Any suggestions?
BalajiVeera
Looks like ArcGIS datastore (Relational) not configured well. Try to validate the same from ArcGIS Server Manager --> Site --> Data Store. If it fails, un-register it (both Relational & Tile Cache) and try to re-configure the ArcGIS Data store using the url with machine name https://MachineName:2443/arcgis/datastore
Hope better to keep backup using backupdatastore utility
EinarDørheim1
Thanks for the suggestions Balaji Veera, unfortunatley they did not work.
However since I already had un-registered the data stores i tried to uninstall and re-install Arcgis Datastore and configure it again towards the old content directory c:\arcgis\arcgisdatastore, which gave me the same error as before. Then i renamed the old content directory to  c:\arcgis\arcgisdatastore_old and configured data store once again to c:\arcgis\arcgisdatastore - forcing it to create a new folder from scratch. This did the trick and I manage to get my data stores up and running again.
Off course this solution means that none of my data from the old datastores are available at the moment, but I have them in the backups, next step will be to find a way to import them into.
StephenKaranja
I ran into the same error while upgrading ArcGIS Enterprise from 10.7 to 10.8. Portal for ArcGIS and ArcGIS Server (and their web adaptors) upgraded without issue, but after installing ArcGIS Data Store 10.8, the Data Store Configuration wizard gave the error below:
Attempt to configure data store failed. Caused by: Runtime error detected for one or more operations on the ArcGIS Data Store configuration store. Caused by: Failed to get file permission.
I also tried stopping the ArcGIS Data Store service, renaming the content directory from C:\arcgisdatastore to C:\arcgisdatastore_old and restarting the service. After this, I was able to successfully configure ArcGIS Data Store with new Relational and Tile Cache data stores, and a new content directory C:\arcgisdatastore. The problem with doing this is that you can't restore the data in your old data stores, which kind of defeats the purpose of upgrading, if you have a lot of existing data (hosted feature layers or scene layers) that you need to continue using in your upgraded system.
The solution that worked for me was to upgrade ArcGIS Data Store and retain the old content directory C:\arcgisdatastore. After installing ArcGIS Data Store 10.8, I closed the Data Store Configuration wizard without doing any configuration with it. I then used the restoredatastore utility to restore both the Relational and Tile Cache data stores from backups that I had created earlier. The restore followed the steps documented here.
SineKelly17
Hi @StephenKaranja can you remember if after you restored the datastores, was that the end of the process or did you then need to configure them again as well?
StephenKaranja
No, I didn't need to perform additional configuration after running the restoredatastore utility. However, I validated the relational and tile cache data stores with ArcGIS Server Manager to make sure that they had been restored successfully.
SineKelly17
Okay thanks. In my situation we are not doing an upgrade, simply a tile cache datastore is being configured for the first time (on top of existing relational datastore). Therefore there is only a relational datastore that needs to be backed up/restored. I am trying to work out whether to to restore the relational datastore, and then configure just the tile cache store, OR, configure both the relational and tile cache datastore, then restore the existing relational store.
StephenKaranja
In your case, I would think that you'd only need to configure the tile cache datastore using the Data Store Configuration wizard. There would be no need to do a backup and restore of the relational data store. Are you getting the file permission error when trying to configure the tile cache datastore?
SineKelly17
Yeah it is when trying to configure the tile cache datastore using the Configuration Wizard is when the runtime error message is received:
Runtime error detected on one or more operation on the configuration store, with message:'{0}'.. Extended error message: Failed to get file permission.
The relational datastore already exists and is fine.
StephenKaranja
I'm not sure how one would handle the error in your case since it seems you are trying to create a new tile cache datastore where one doesn't already exist. In my case, I already had both relational and tile cache datastores and only needed to restore them from their backups.
Maybe you could reach out to one of the Esri staff on this community forum to see whether they might better help you troubleshoot the issue.
