Measurement between selected features
657
12-09-2025 07:50 PM
MarkJeynes
In ArcGIS Enterprise, is there a way to select two features from a layer plotted to the map and calculate the distance between them?
I note there is a measurement tool.  However this appears to rely on a manually selecting locations by crosshair which is as accurate as the mouse operator.  I had hoped for the tool to support picking the coordinates from selected features themselves.
RyanUthoff
MVP Regular Contributor
I don't believe this is possible in just the web map itself, but it is possible by using the measurement tool in Experience Builder starting with ArcGIS Enterprise 11.4+ or the ExB Developer edition 1.5+.
https://community.esri.com/t5/arcgis-experience-builder-ideas/allow-snapping-in-measure-tool-for-exp...
Eugene_Adkins
If you're using Pro, you can use some proximity related tools.
Priya_Das
Hi @MarkJeynes
You can use the Find Nearest tool uses either a line distance or a travel mode to measure between input features and near features.
https://enterprise.arcgis.com/en/portal/11.4/use/find-nearest.htm
