Map Viewer Beta 10.9
4047
13
05-20-2021 07:34 AM
mpboyle
We just added the Map Viewer Beta to our 10.9 Enterprise, and I've had the following issues, and am just wondering if anyone else has had similar issues:
  • The "Search for Layers" tool doesn't work for anything, not even my own content
  • The following properties remain grayed out for map image layers:
    • Styles
    • Filter
    • Clustering
    • Configure Pop-ups
    • Configure Fields
    • Labels
I was kind of looking forward to trying it, but it seems pretty unusable at this point at 10.9.
ZacharyHart
Honored Contributor
Alas, we don't have that luxury...
Good luck and thanks again.
DavidColey
MVP Frequent Contributor
Yeah ok so none of that worked at 10.8.1 beta and won't work now.  I'm sure you've figured this out already, but for straight up dynamic map services, you (or at least I did) have to add your layers to the beta's TOC one layer at a time from the rest url, (i.e  /0, /1 etc) unless you have feature access enabled.  Feature access enabled on the service allows you to add the layer like a hosted layer.
Todd_Metzler
Agree.  Some of the functionality limitations in Map Viewer (BETA) in Enterprise inhibit full implementation.  Here's what I've discovered and why I'm still telling my publishers to use it.
A feature service type with synch enabled is a prerequisite to create Field Maps download enabled base maps with content.  I'm leaning toward instructing all our publishers to publish Feature Service type with synch enabled as standard.  Then you can search and discover these in Map Viewer (BETA).  Downside, more ArcSOC processes on the server.  For now, I can accept this because I've plenty of resources.
Good luck!
Todd
JamiePetersen
I can confirm that map image layers cannot be added to the 10.8.1 release either.  Further, the same exact map image portal item that is synchronized to our ArcGIS Online organization via collaboration is able to be added to the ArcGIS Online version of Map Viewer Beta.  So, it is only the Enterprise Map Viewer Beta that does not handle them.
