Our hosted ArcGIS Enterprise 10.6 system started showing errors after a Windows Server 2016 update. There are validation errors against Managed Database, Spatiotemporal and Tile Cache as shown in below picture:
In the Logs tab, I notice following two messages:
SEVERE | Mar 29, 2020, 6:29:26 PM | The connection property set was missing a required property or the property value was unrecognized. Instance not available on server | DataValidator.GPServer |
WARNING | Mar 29, 2020, 6:29:14 PM | Failed to validate the data store machine 'URL'. 'Server machine 'URL' returned an error. 'Invalid Token.'' | Admin |
Appreciate if someone could direct me in the right direction. Thanks
Farakh
I had this problem with just the managed database. Running the update licence tool fixed it.
Thanks Vicky,
I ran the updatelicense.bat command but received following error message:
Error encountered: No relational data store configured. This operation only allowed on a relational data store.
Farakh
Hello Farakh,
It sounds like there is an issue with the relation data store. I would recommend running the 'describedatastore' utility. This returns status information regarding data store. Based on the error messages and the validation failures server may be unable to communicate with data store.
Examples:
ArcGIS Data Store command utility reference
Hope this helps!
Thomas.
Thanks Thomas,
I'm getting the following error while running the describedatastore command:
Error encountered: The data store machine may not have been initialized.
I'm not sure if I should run registerdatastore command (considering the first error: "No relational data store configured") as this problem arises with a fully-working system already having many feature layers, Survey123 Forms and dashboards etc.
Farakh
Hello Farakh,
If you are not able to run the describedatastore command I would also expect registerdatastore to fail with the same error message. It appears currently that you are not able to connect to ArcGIS Data Store. Can you verify that the ArcGIS Data Store Windows service is running? If running restart the Windows service. If the Windows service is running I recommend checking if the ArcGIS Data Store processes are running using Task Manager.
If you are still unable to run the describedatastore command I would recommend creating a case with Technical Support to troubleshoot further.
Thomas.
Dear Thomas, Thanks again. I found all three Data Store processes running in Task Manager. Restarted services and ran describedatastore command again but same error message. As you suggested, I guess it's time to contact Technical Support.
Farakh
Farakh,
Did you get the issue resolved? I am experiencing the same thing. Thanks!
