Limit on featureclasses in featureservice, performance drop.
1291
06-02-2025 06:46 AM
RobertBlok1
We are using ArcGIS Enterprise 11.2, ArcGIS Pro 3.4, Postgress Database and a MGCP datamodel that includes more then 350 featureclasses.
All of the featureclasses are published in one featureservice. Every new feature or edit task takes about 7 seconds to finish.
ArcGIS.Desktop.Editing.CreateSketchTool.OnFinishSketch takes most time.
If we create a featureservice with only 13 featureclasses, the performance is very good. Zero wait.
Is there an advisable number of featureclasses in a featureservice with good performance?
George_Thompson
Esri Notable Contributor
That seems like a lot of layers in a service. How many instances of the service do you have running and how is the memory of the ArcSOC's on the machine hosting the service?
--- George T.
RobertBlok1
The maximum of instances is set to 20. There is no indication that we are on the max. Memory on the server is most of the time less then 60%.
Scott_Tansley
MVP Regular Contributor
I have always worked on the basis that 20 is a nice number of layers in a service, 50 is still okay, 100 is questionable.
I try and theme my services to contain the required layers and keep them short and snappy.
There is no precise answer, it's a bit of trial and error but 1 service with 350 doesn't fell right at all, sorry.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
RobertBlok1
I published it today en kept it to a max of 50 layers per service.
I've noticed a considerable increase in performance after moving the layers outside of the featuredataset (and the max of 50 layers per service).
Scott_Tansley
Yeah feature datasets are not the logical container that everyone thinks they are.  They're for advanced spatial types only, and not a 'folder'.  Have a read of this:
https://esriaustraliatechblog.wordpress.com/2011/10/06/can-you-use-feature-datasets-as-logical-folde...
Its old, but still current.
Scott Tansley
