Issues with configuring LDAP with ArcGIS Enterprise 11.1
1751
08-31-2023 06:49 PM
DeepikaJain01
Dear Community
I am trying to configure LDAP with ArcGIS Enterprise through Ldap and Windows configuration in Portal admin configuration store in Security. However, it generates me the same error in both the cases
Error
com.esri.arcgis.portal.admin.core.PortalException: java.lang.Exception: Could not connect to the user store. Please check the configuration and try again.
Code: 500
The user used in the configuration does have the access to LDAP, I am not sure whats causing it.
asergio
Hi @DeepikaJain01 ,
Check using the Test-NetConnection power shell command that the Portal for ArcGIS server has connectivity to the LDAP server.
A_Wyn_Jones
You can go to the Identity store configuration at portaladmin/security/config and use the "Test identity store" button once you're config is in place.
The error you are getting looks like ports 3268-3269 may be blocked (for Windows authentication via AD). Turning on debug logs when configuring the Identity store gives good feedback on which ports are being contacted in your setup.
Hopefully will help you resolve the problem
"We've boosted the Anti-Mass Spectrometer to 105 percent. Bit of a gamble, but we need the extra resolution."
