Is it possible install ArcGIS for Server on Linux without graphic enviroment?
4041
05-11-2016 09:24 AM
NorwillGutierrez
I'm newbie on ArcGIS, recently (yesterday) install ArcGIS for Server 10.2.2 on Suse Enterprise 11 SP4 everithings go ok until i try to start the server.
When i try to start the server from installdirectory ./startserver.sh return this:
ERROR: Unable to start Xvfb on any port in the range 6600 - 6619.
This installation is on azure without graphic enviroment (initially) then i install the graphical enviroment and still present this error.
Any idea to solve this?
Thanks in advance.
AnthonyKobah
Hi Norwill,
Run the Server Diagnostic Tool to help troubleshoot the issue. See link
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
NorwillGutierrez
Hi Anthony thanks for you reply, when i run the diagnostic show this:
<PROMPT_CHECK_ROOT_INSTALLER>                             <STATUS_PASSED>
<PROMPT_CHECK_OS_ARCH>                                    <STATUS_PASSED>
<PROMPT_CHECK_OS_VERSION>                                 <STATUS_PASSED>
<PROMPT_CHECK_HOST_NAME_BAD_CHARS>                        <STATUS_PASSED>
<PROMPT_CHECK_INSTALLED_PACKAGES>                         <STATUS_PASSED>
<PROMPT_CHECK_SYSTEM_LIMITS>                              <STATUS_PASSED>
<PROMPT_CHECK_OS_PATCHES>                                 <STATUS_NA>
<PROMPT_CHECK_SERVER_PORT>                                <STATUS_PASSED>
<PROMPT_CHECK_HTTPS_PORT>                                 <STATUS_PASSED>
<PROMPT_CHECK_XVFB_PORTS>                                 <STATUS_PASSED>
<PROMPT_CHECK_HOST_NAME_ENTRIES>                          <STATUS_PASSED>
<PROMPT_CHECK_CORE_SERVICES>                              <STATUS_WARNING>
When i run the installation all the items marks as passed, right now i have the url working here:
ArcGIS
I start manually tomcat.
I need to start the server anyway using the xfvb ?
AnthonyKobah
Norwill Gutierrez
So, it appears the XVFB server is good. Check if the needed port is opened. One port within this range 6600-6619 is needed by ArcGIS Server.
Run this command in terminal. "netstat -lntu". You might need to open the port for it to work.
NorwillGutierrez
Thanks  again Anthony you give me a great idea.
with the command netstat -lntu i see the ports listening and change the por for xvfb now is running all ok.
The next step is configure web adaptor, is installed and copy the file arcgis.war to bin tomcat folder but i can't acces to the url.
Any idea?
