Is ArcGIS Server 10.1 working well in 'Failover' infrastructure?
1257
01-01-2013 07:45 PM
larryzhang
Happy New Year, Team,
We need your assistance on the following scenario:
We are taking action to migrate an existing �??Failover�?? system of ArcGIS Server 10.0 (SP5), which was constructed with two machine nodes (one is Active, another Passive) and managed by Windows Server 2008, into �??Failover�?? ArcGIS Server 10.1 (SP1).
As first step, all installation and configuration at the �??Passive�?? node look fine. All services can be accessed via this host IP address.
However, when we try to manage this �??ArcGIS Server 10.1�?? as EMP Cluster resource via �??EMP Cluster Group�?? manager in order to be accessible through the �??virtual�?? IP address at the Cluster, it failed. The error message show below:[INDENT]Service:  ArcGIS Server (ArcGIS Server)
Resource:  Generic Service
Parameters:  Files\ArcGIS\Server\framework\etc\service\bin\ArcGISServer.exe
Started 1/2/2013 8:13:57 AM
Completed 1/2/2013 8:13:58 AM
Creating the Generic Service resource.
Do not use network name as computer name.
An error occurred while creating the resource Generic Service.
An error occurred while configuring the Generic Service resource.
Unable to save property changes for 'ArcGIS Server'.
The specified service does not exist as an installed service
[/INDENT]
It seems that ArcGIS Server 10.1 wouldn�??t support �??Failover�?? infrastructure anymore. If so, we have to restore ArcGIS Server 10.0 back. Isn�??t it correct?
Any advices on 'Failover' to proceed with 10.1?
Or do we have to construct a new infrastructure with �??load-balancing�?? solution for 10.1?
All Best
Note,
  1. ArcGIS Server 10.0 (SP5) are very stable in �??Failover�??;
  2. For 'Failover Clusters' in Windows Server 2008 R2, link at http://technet.microsoft.com/en-us/library/ff182326(v=ws.10).aspx
nicogis
can you give further details on your configuration cluster-failover in 10.0? Where have you som and soc?
EyadHammad
Good day,
do you have any update on this issue?
could you get ArcGIS Server 10.1 working on failover environment ?
nicogis
see http://resources.arcgis.com/en/help/main/10.1/0154/015400000488000000.htm
"Site: A site consists of several components, such as a GIS server and ArcGIS Web Adaptor, that can optionally be distributed across multiple machines to increase computing power and redundancy"
JustinRodriguez
[/INDENT]
All Best
Note,
Hello
Machines in the same cluster will failover without any additional configuration. Thanks-
Justin
