Increase File/Attachement Size Enterprise
2406
04-06-2020 09:17 PM
MarcoPoetsch
Hi there,
I'm wondering if it's possible to increase the maximum file size in Survey123 (Connect) if the survey is hosted on Enterprise/Portal.
I know there is a limit of 10MB in ArcGIS Online, but maybe there is an option if its not hosted by ArcGIS Online?
Thanks a lot,
Marco
JamesTedrick
Esri Esteemed Contributor
Hi Marco,
I don't believe that it is possible to set the single-part upload size limit in ArcGIS Enterprise.
MarcoPoetsch
Thanks James,
so i guess this workflow wouldn't work then?
How To: Manage the upload file size for attachments in a feature service
Do you know any workaround? I would like to be able to upload short video clips (about 10-20MB each).
Marco
JamesTedrick
Hi Marco,
That may work for some services, though you would need to see if there is a matching attribute for the hosted data store.  This would be better answered in ArcGIS Enterprise
Marcus
Hi,Have the same question but for images,
Would it work with uploading images higher than 10mb using Suvery123 Connect with ArcGIS Enterprise?
Thanks
Marcus
