I cant Reach login page to ArcGIS enterprise
1029
10-12-2023 03:15 AM
AhmedTarek123
I Configured ArcGIS Enterprise  But I cant Login in Sign in page WhatsApp Image 2023-10-12 at 13.09.58_254dac6d.jpgWhatsApp Image 2023-10-12 at 13.09.58_497e3786.jpg
AhmedTarek123
ArcGIS Enterprise Version Is 11.1
Dan_Brumm
I have a ticket open with ESRI for the exact same issue.  I can reach the sign in page if I go through the port 7443. If I try the web adaptor it times out.  They believe its either a proxy setting or certificate issue.
Daniel Brumm
GIS Nerd
ArchitSrivastava
Hello @AhmedTarek123 , @Dan_Brumm ,
I would like to suggest something here and would be worth a try (I have used the same workflow to fix similar problems in past for myself) :
  • Navigate to portaladmin endpoint using 7443 URL
  • Under Home > Security > OAuth > Get App Info > search for arcgisonline
  • This is the client ID which is authorized while you are logging into Portal Home.
The entries here should have your "https://<portal.domain.com>" URLs  for proper redirect to happen to sign-ins.
Majorly, what I have seen here is are as follows:
For more details check out this Get App Info—ArcGIS REST APIs | ArcGIS Developers
If you do not see the you organization URLs in this JSON result, you can use Update App Info—ArcGIS REST APIs | ArcGIS Developers to update this to appropriate URLs.
Note : Make sure the JSON is properly formatted, if you are making any changes
Hope it helps!
-Archit
Dan_Brumm
Archit
Thank you for the suggestion. We did try digging into the oauth settings. When this issue first popped up it was my first thought.  I have tried every combination of ip address / machine name/ public URL and it never makes any difference. Same error everytime.
I still beleive / hope this is a certificate issue because we have  tried every other solution.
Daniel Brumm
GIS Nerd
