FINALLY I solved that problem,
actually when I wasn't able to add the IIS APPPOOL/ArcGISWebAdaptorAppPool v4.0 user to my webAdaptor file, I changed the owner of the file from "administrator" to "system" then simply added the user "everyone" as a user of the file and give it full control over it and that solved my problem, so the instructions are:
1. Install your 1st web adaptor, and you name it 'waportal' > don't register anything in here
2. go to c:/inetpub/wwwroot -> copy 'waportal' and paste on the same place c:/inetpub/wwroot/
by default second wa name is 'waportal copy'. rename it, for example 'waserver'
3. you have to convert 'waserver' as application. go to IIS Manager > in the left side expand Default Website > right click in waserver, choose convert to application
4. chnage the owner of the file webadaptor.config from administrator to "system" and then try to add the user "IIS APPPOOL/ArcGISWebAdaptorAppPool " and give it full control, if that doesn't work, add instead "everyone" user.
5. you have 2 wa right now. the first is waportal and the second is waserver.
a. register your portal on your waportal
go to http://yourhost/waportal/webadaptor/ > select portal for arcgis then follow the instruction
b. register your arcgis server on your waserver
go to http://yourhost/waserver/webadaptor/ > select arcgis for server then follow the instruction.
