Hosting server required to register data to a server?
1480
12-14-2021 08:08 AM
RandyMcGregor3
This conflicts with what I thought, but I may be mistaken. The checkmark is in the 'Hosted Feature Service' column (frozen column headers would be great in the documentation, fyi).
It's from here
https://enterprise.arcgis.com/en/server/latest/deploy/windows/about-using-your-server-with-portal-fo...
Could I get confirmation that the server has to be designated as a hosting server to be able to host registered map services?
MichaelGinzburg
Sign in to the portal website as an administrator and browse to Organization > Settings > Servers
To be hosting, the server should be added to the Portal and be federated:
https://enterprise.arcgis.com/en/portal/latest/administer/windows/configure-servers.htm
Then a federated server may be assigned as hosting:
https://enterprise.arcgis.com/en/portal/latest/administer/windows/configure-hosting-server-for-porta...
I presume that if your server is defined as hosting - it will be listed as such on your Portal Organization > Settings > Servers page.
RandyMcGregor3
Thanks Michael,
I was actually just wondering if the hosting server designation was a requirement for being able to register GIS data to the server so it can be published as registered map services. I had thought that designating a server as a hosting server was only necessary for allowing data to be copied to that server - ie to publish hosted servers.
Randy
MichaelGinzburg
To my knowledge, a hosting server is not required for publishing services.
https://enterprise.arcgis.com/en/server/latest/manage-data/linux/registering-your-data-with-arcgis-s...
Hosting server is required if you want to upload data through Portal.
