Hosted Feature Services Not Restoring Correctly
1543
02-27-2024 02:57 PM
NathanHeickLACSD
I was performing a restore using webgisdr.  Some of the hosted feature services would not load into the Map Viewer after the restore.  I noticed that in the config-store/services/hosted, the folders were missing for those services.  The items were present in the portal.  Does anyone have an idea what could cause this?
In the short term, I copied these folders from the backup into the hosted folder and the services worked, but I don't trust that other things may not be wrong as well.
Nathan
drunneals_cgs
Ran into this same issue. I noticed they were missing from the [ArcGIS Server System Directory Path]\arcgisinput folder along with [ArcGIS Server Config Store Directory Path]\services folder. Do you remember if WebGISDR said it succeeded? Mine definitely did, and I was surprised to see that many services were missing, though they existed in the WebGISDR backups. I'm shocked WebGISDR doesn't have any checksums built in.
One thing I did notice is that in config-store\services\Hosted\[FeatureServiceFolder]\[FeatureServiceName].FeatureServer.json there was a json tag that appeared to tag them to an earlier version, in my case: "currentVersion": 10.51. Don't know if this was an issue or not.
See related post here.
NathanHeickLACSD
From what I remember, it was successful.  It might have also been that I wasn't logged in to see all of the services because they weren't all shared publicly.
