Feature services support for HTML pop-ups
7279
6
02-24-2015 01:44 PM
WarrenMedernach
Hello all,
In the following link it states:
HTML pop-ups
Feature services support HTML pop-ups configured in ArcMap. HTML pop-ups are a powerful and easy way to share HTML-formatted information about features. They work much like the Identify tool, except that the displayed information can be customized HTML. For more information about how to set up HTML pop-ups in ArcMap, see Setting HTML pop-up properties for feature layers.
I have an HTML Popup configured in a map as a URL, that is calling an aspx page and displaying a Google Chart in the HTML popup.  This is awesome and works great!  So, once I publish this layer as a service, how are these popups configured/consumed in a web map on AGOL?  IOW, how does one 'use' the HTML popup content as the feature service pop-up?
Thanks for any help.
Warren
WarrenMedernach
<iframe>!!!!
For those looking to display the results/content of a webpage in popup on AGOL without custom coding, simply wrap your URL in a HTML iframe tag:
<iframe height='300px' src='http://your_server.com/some_webpage.aspx?some_param=some_value'></iframe>
The height/width attributes of the frame will expand the popup size.
Hope this helps someone.
Warren
WarrenMedernach
Hello... ello... llo... lo...
Anybody?  Suggestions, comments?  Am I missing something so obvious that I should be embarrassed for asking this?
Warren
MattiasEkström
Warren, when consuming your service in a web map in AGOL I think you have to configure the pop-up in AGOL. This is from the page you linked to:
"If you work with your feature service on the web and you want pop-ups to be available, consider defining them in theArcGIS.com map viewer instead. Alternatively, developers can use the client API itself, such as the ArcGIS API for JavaScript, to define pop-up styles."
Check out this link to read more about configuring poups in a web map.
http://doc.arcgis.com/en/arcgis-online/create-maps/configure-pop-ups.htm
WarrenMedernach
Thanks Mattias,
I guess what I was saying is that, configuring the popup in AGOL is not working in the same way as the HTML popup.  I can display the URL as link, but I cannot display the 'contents' of the URL in the popup.  I'll likely just have to move it all into my own web template and build it out from there.
Warren
MarkBockenhauer
If the attribute is <html>  tagged, it can sometimes work....
WarrenMedernach
Thanks Mark,
I've tried wrapping it in an <a href> tag, and all variations of popup configurations but still no luck.  Do you have a sample of the html format that worked for you?
Warren
WarrenMedernach
<iframe>!!!!
Warren
