Error "ArcSOC not bounded to RMI Registry" in ArcGIS Server Log
1694
07-22-2024 08:14 AM
MHahn
I did an Upgrade of my Single Machine Deployment Portal from 11.1 to 11.3
After the upgrade all services worked well so I didn´t look closer. The next morning some services "didn´t wake up" and took 1 min or longer for the response.
In the log I found the following message for every service
"ArcSOC not bounded to RMI Registry with contextID: xyz"
Because I couldn´t find any information, I decided to try a migration to a fresh installed machien with webgisdr.
Now the restore is interrupted with the same error message.
Does anyone have informations about this error?
Thanks!
TomShewring
I also found these errors after upgrading from 11.1
I have recovered my deployment.
I found the issue was
arcgisserver\config-store\machines\<servername>.<domain>.json
And
arcgisserver\config-store\version.json
were both corrupted.
I stopped the ArcGIS Server service and copied these files in from another similarly configured ArcGIS Server deployment and then renamed / configured the files appropriately for the server with the issue, then restarted the ArcGIS Server instance.
MHahn
Hi Tom, thanks for your answer.
That didn´t helped me.
But what do you mean by "corrupted" I could open and edit the files.
Martin1
@MHahnDid you ever find the reason for your issues. I see the same error on several Geocoding services.
MHahn
Sorry. No. I installed a new Enterprise ..
