Error 80070035: Network Path Not Found
4057
02-20-2019 12:34 PM
DondreTrotman
Hi there,
I recently uninstalled Arcserver 10.4 and I am trying to re-install ArcServer 10.4 with the same domain OS account 'domain\arcgis' as before.I am experiencing an error which states 'Error 80070035: Network path was not found' as outlined below:
https://support.esri.com/en/technical-article/000012113
I tried the first workaround which states to automatically configure the arcserver account on the IIS server to access the Arcserver machine as outlined below but it still didnt work:
Could someone help?
Thank you.
AJJohnson
I would suggest attempting to install ArcGIS Server 10.4 using a local account instead of a domain account.  After installing ArcGIS Server 10.4 you can open a program called "Configure ArcGIS Server Account" where you can then attempt to change the ArcGIS Server Account to a domain account.
You should also go to Control Panel > System and Security > System and make sure the computer is actually connected to a domain.  As you can see below, my computer is connected to the esri.com domain.  If the computer is not connected to a domain, then I imagine you will not be able to configure ArcGIS Server 10.4 with a domain account for the ArcGIS Server Account.
