Enterprise
1859
03-02-2020 08:47 AM
JayeetaChakraborty
Can you suggest a good online course to learn ArcGIS  Enterprise? How much does the software cost?I would like to go for a certification later.
JoshuaBixby
If you are starting out from scratch with ArcGIS Enterprise, which it seems you are, it will be a sizeable time and financial commitment to get certified in ArcGIS Enterprise.  If you don't work for a company/organization that already has access to ArcGIS Enterprise licensing, then an ArcGIS for Developers subscription is probably the least expensive way to get access to all of the various components that make up ArcGIS Enterprise.  That said, the minimum Developer plan that includes ArcGIS Enterprise is Professional at $1,800/yr.
DerekLaw
Esri Esteemed Contributor
Hi Jayeeta,
In addition to what George and Joshua posted, please see my comments in your other similar topic thread where I've reference some video links you can watch
Arc Enterprise?
Hope this helps,
