Enter/Change bing maps license key for ArcGIS server ... how and where?
2105
7
01-15-2014 11:59 AM
DavidLeary
so go easy here, i am an IT sys admin who inherited a few GIS guys who use ArcGIS server. i have ran down how to setup the bing map licenses and patch ArcGIS desktop to enter in the new keys. but i cannot find how to do this for ArcGIS server. anyone? i believe we are running 10.1
NidhinKarthikeyan
Honored Contributor
The ability to retrieve your Bing Maps key using Manager has been removed at 10.1. You should visit the Esri Customer Care website or contact your Esri customer service representative to find out your key.
Take a look at webhelp: Bing Maps overview.
DavidLeary
i have the key, i just don't know where to change it.
nicogis
AdamMarinelli
If you are running 10.1 then you will need SP1 and then download this patch:
ArcGIS 10.1 SP1 (Desktop, Engine, Reader) Set Bing Key Patch
http://support.esri.com/en/downloads/patches-servicepacks/view/productid/160/metaid/2003
You should then find an executable called SetBingKey.exe in the \bin folder in the location you installed ArcGIS.
The default location is Program Files (x86)\ArcGIS\Desktop10.1\bin
The resource that @ciava.at provided has all this information for different ArcGIS releases.
DavidLeary
so will this work on arcgis server? am i to assume the instructions for the desktop are the same for arcgis server?
JonathanQuinn
Esri Notable Contributor
ArcGIS Server 10.1+ does not support entering a Bing key anymore.  What workflow are you using to access Bing?  If you're using a web application, imbed the Bing key within the application.
JaredLee
I have been searching online for this information off and on for days.
Glad I checked in here. Your post solved the problem for me.
Thanks!
