I am publishing a service with only mapping capability enable and using the map service in a web map. Even though I specified the time zone my data is in on the Parameters tab, the data timestamps are shifted in the web map. If I enable the feature service capability, the data timestamps are display correctly in a web map.
The only way I found to make the timestamps show correctly was to time-enable every layer in my mxd before I publish it from ArcMap.
Is this how it works?
