Data Store - Register Edit Tools Issue
547
11-11-2022 08:16 AM
JD1016
Hello,
I've recently installed ArcGIS Data Store 10.9.1 and am encountering an interesting "glitch" which I hope can be easily remedied.  I've tried uninstalling and reinstalling Data Store but that did not eliminate the issue.  I've attached a screenshot that explains the issue I am experiencing regarding the edit tools vanishing after certain procedures.
Thank you.
Jeff
ReeseFacendini
Esri Alum
The edit icon for the ArcGIS DataStore connections cannot be edited in the same way as other connections because they are managed by the Enterprise system. You can remove those connections, if you added one by accident, but you can't edit the connection properties.
JD1016
Thank you for responding to my post, Reese.
The connections that I would like to edit are the folders I created for Jeff and GIS Databases.  I can edit once upon entering the system, however, once I save my corrections, all the edit tools disappear completely.  I'm not talking "grayed out".  They are completely gone from the graphic.  They only return if you go completely out of Manager and come back in again.
