Create Enterprise Geodatabase Error.. Error connecting to database as geodatabase admin.
5369
05-28-2019 12:51 AM
PriyaAggarwal1
I am trying to create first enterprise geodatabase in PostgreSQL. this error occurs. What should I do?
Below the error:
Executing: CreateEnterpriseGeodatabase PostgreSQL (IP Adress) MyData DATABASE_AUTH postgres ***** SDE_SCHEMA sde ***** # "keycodes"
Start Time: Tue May 28 13:03:52 2019
User has privileges required to create database objects.
Geodatabase admin user created.
Database created.
Failed to execute (CreateEnterpriseGeodatabase).
Failed at Tue May 28 13:04:10 2019 (Elapsed Time: 17.88 seconds)
Thanks for the help in advance.
George_Thompson
Esri Notable Contributor
Are you using ArcGIS Pro or ArcMap/ArcCatalog for the GP tool?
Can you try to name the GDB in all lower-case; https://pro.arcgis.com/en/pro-app/help/data/geodatabases/manage-postgresql/setup-geodatabase-postgre...?
Have you followed the steps in the above help for creating the EGDB within Postgres?
Geodatabase
--- George T.
PriyaAggarwal1
Hi Thompson,
I'm using ArcMap 10.2.2.
When I run Create EGDB tool for making EGDB in postgreSQL, than a SDE user and schema is auto created in postgreSQL but this SDE connection is not becoming geodatabase administrator.
I move st_geometry.dll file to C:\Program Files\PostgreSQL\10\lib, but still postgres is not creating Geo database.
I am not sure about the issue, may be its postgres or arcmap version compatibility issue.
George_Thompson
What is the version of Postgres that you are using?
Here are the supported Postgres versions for 10.2.x; https://resources.arcgis.com/en/help/system-requirements/10.2/#/PostgreSQL_Database_Requirements/015...
I would HIGHLY recommend moving to at least 10.7 or use ArcGIS Pro 2.3.3 (latest version).
--- George T.
