Blurry annotation and line work with new arcgis server 10.1 and api 3.1
928
03-12-2013 07:28 AM
eddiequinlan
Not sure if this is a server issue, arcgis10.1 issue, or 3.1api issue.  However, since I've update all my software i've noticed the quality of my annotation and line work on my web app services are blurry when viewing the web page.  If you zoom in very close there isn't a problem, but prior to the updates i could view the web page at various scales and still maintain clarity.
Any thoughts?
DustinNelson
What are your Anti-Aliasing parameters set at for the service?
eddiequinlan
Thanx for the response Dustin,
Currently my parameters settings for the service are  Anti-Aliasing = Best;  Text Anti-Aliasing  = Force.  I've experimented with the settings and you can tell they do have an affect on the clarity of the map.  However, the 2 settings above give the best clarity, and it is definitely worse than my same service running server 10.0.  Currently I am "cloning" the server to run 10 and 10.1.  This allows me to keep 10 running for all my current users, until I 10.1 is running properly with all of it's services and mxds.  It also allows me to compare my flex projects/map services to each other on the two different arcgis versions.
Eddie
