Data format for publishing services
1221
03-12-2013 02:01 PM
WolframLange
Hello all,
is there any advantage/disadvantage to use shapefiles or personal geodatabase as data source to be send to ArcGIS for Server 10.1 when publishing a service?
What is the data format that ArcGIS for Server 10.1 is storing the data? Any difference which data format the source data is?
Thanks for any answer!
Best regards,
Wolfram
StevenMoore1
Hi Wolfram,
Personal Geodatabases are no longer supported with ArcGIS Server 10.1, so I would not recommend using that to store data you want to publish. This is documented under the 'Discontinued Functionality' section at the following link:
http://resources.arcgis.com/en/help/main/10.1/index.html#//0154000002p0000000
As far as shapefile and file geodatabase, there shouldn't be any difference in performance if you copy the data to the server when you publish. If you copy data, it will be stored in a file geodatabase on the server and the service will reference that.
If you do not copy the data to the server, then you would see the best performance storing your data in a file geodatabase rather than in shapefile format. The following link has some old but still relevant information on FGDB performance:
http://www.esri.com/news/arcuser/0309/files/9reasons.pdf
Hope this helps.
StevenMoore1
Hi Wolfram,
Hope this helps.
nicogis
Steve, you cannot use personal gdb in 10.1 (also in soe)
WolframLange
Hey Steve,
thanks for the answer, that's it!
Best
