ArcGIS Web Adaptor 10.9.1: Configuring the Web Adaptor ends up with an “unable to connect” error,
5243
8
06-13-2022 11:44 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out why configuring the Web Adaptor ends up with an “unable to connect” error as per the screenshot below.
What could be the issue here?
Jamal Numan
JonEmch
@JamalNUMAN
When installing the web Adaptor, make sure that you choose the 443 binding, this is the https port. In my experince, this is easy to miss especially if you let the Web Adaptor installer handle installation of IIS.  My advice to you is to:
  • Uninstall the current Web Adaptor,
  • Go to IIS, create the 443 binding on your default site with the appropriate certificate (optional, but recommended)
  • Re run the the Web Adaptor installer ensuring to select the https (443) option
This should make it available to be hit over https.
Keep on keeping on!
BillFox
MVP Notable Contributor
try using the fully qualified domain name
JamalNUMAN
This is a test machine. It’s used to work this way in the earlier versions of adaptors.
Jamal Numan
Scott_Tansley
MVP Regular Contributor
if your test machine is not on a domain, then the FQDN equivalent will be something along the lines of https://jamalnuman2.local  always better to use the FQDN when making any form of configuration.
Does it connect if you just want the root?  What did you call the web adaptor when you installed it?  I haven't seen 'adaptor' used before for the context.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
George_Thompson
Esri Notable Contributor
It looks like you have second level context in the URL: "machinename/adaptor/webadaptorname/server"
"If you do not use ArcGIS Web Adaptor in your deployment, ensure that the reverse proxy server's context name only goes one URL level deep. For example, you can have a reverse proxy URL such as https://proxy.domain.com/enterprise, but you cannot have a reverse proxy URL such as https://proxy.domain.com/myorg/enterprise."
https://enterprise.arcgis.com/en/portal/latest/administer/windows/using-a-reverse-proxy-server-with-...
--- George T.
JamalNUMAN
My observation is:
As the ArcGIS Web Adaptor starts, the link is
http://localhost/adaptor/webadaptor
As the “GIS, Image, Workflow Manager, GeoAnalytics or Knowledge Server” option is selected and the “next” button is clicked, the link is redirected to:
https://jamalnuman2/adaptor/webadaptor/server
if the https is replaced by http, then it should work
http://jamalnuman2/adaptor/webadaptor/server
How can the adaptor be accessed with the https even if the https is not configured as this works for the services directory?
http://localhost:6080/arcgis/rest/services
https://localhost:6443/arcgis/rest/services
Jamal Numan
JonEmch
@JamalNUMAN
Keep on keeping on!
JamalNUMAN
Thank you JonEmch for the help. It works fine as per the screenshots below
Jamal Numan
JonEmch
Awesome! Glad to hear that this worked.
Keep on keeping on!
