arcgis server site manager takes several minutes to load
830
6
07-04-2018 08:07 AM
SaraEL_MALKI
Occasional Contributor II
Hello there,
I have arcGIS Server 10.5.1 version
when trying to connect to my server site, it takes up to 15 minutes to display the login page !
Here is a part of the errors I get in the console:
PS: I've installed the web adaptor for the server, and I'm acceding to the site via: https://sigserver.domain.com/arcgis/manager
Robert Scheitlin, GISP‌ Rebecca Strauch, GISP
please tag anyone that can helo me in this !!!
ArcGIS Server (10.0 and prior)‌
JonathanQuinn
Esri Notable Contributor
Is the site federated with Portal? From the first error in the console, it appears it is:
If it is federated, Server will try to generate a token through the Portal. It looks like that connection is getting refused for some reason. Can you reach the portal/sharing/rest page in a browser on the Server machine?
RobertScheitlin__GISP
This sounds like a server install issue and you will have to contact support for that.
RandallWilliams
This looks like a name resolution issue to me - the ArcGIS Server hostname isn't fully qualified in that log for some reason, and you're getting a 404.
JonathanQuinn
SaraEL_MALKI
yes that is true, The server is federated with Portal
and I can't reach that page ...
when I remove the federation the site manager works fine, whenever I add it it takes a ton of minutes to load
by the way I didn't add the web adaptor for my server but it's added for the portal ..
JonathanQuinn
So it does load at some point? If Server can't reach Portal, I would expect you'd just see the blue scrolling bar below indefinitely:
I'd suggest you start by troubleshooting why you can't reach https://<portal>.<domain>.com/portal/sharing/rest on the Server machine. Once you do that, then you shouldn't see the ERR_CONNECTION_REFUSED error and hopefully you'll get a bit further. Do you use a proxy to reach the internet on the Server machine? Can you ping the hostname of the Portal? Can you reach that page on the Portal machine itself, or your desktop/another client machine?
SaraEL_MALKI
I marked your answer as correct because trough your remark I was able to spot the error,
I didn't configure my arcGIS Server with the Web Adaptor and I stilled federeated it with Portal wich was WRONG
also I didn't enable https on port 443 on web server which was also WRONG
after correcting these stuff I was able to federate the server with Portal in the right way and then everything worked fine
thank you mister Jonathan
