ArcGIS Server Object Extension (SOE) from 10.3.1 to 10.6.1.
2174
12-17-2019 12:24 PM
WarrenMazoue
We are upgrading ArcGIS Server Object Extension (SOE) from 10.3.1 to 10.6.1. and I'd like to confirm a few things
We have a C# project that currently references - ESRI.ArcGIS.System  (we use two return types, IPropertySet and IServerEnvironment2) is this reference replaced by Esri System Object Library 10.6 (ESRI.ArcGIS.esriSystem;)?
[Update]
I am getting an error here
private THandlerInterface FindRequestHandlerDelegate<THandlerInterface>() where THandlerInterface : class
   try
      IPropertySet props = ServerEnvironment.Properties;
   catch (Exception e)
private IServerEnvironment2 ServerEnvironment
get
      if (_serverEnvironment == null)
         UID uid = new UIDClass();
         uid.Value = "{32D4C328-E473-4615-922C-63C108F55E60}";
         // Create an EnvironmentManager and retrieve the IServerEnvironment
         IEnvironmentManager environmentManager = new EnvironmentManager() as IEnvironmentManager;
         _serverEnvironment = environmentManager.GetEnvironment(uid) as IServerEnvironment2;
   return _serverEnvironment;
[Error]
Instance of service ' AutomationException: Unable to cast object of type 'System.__ComObject' to type 'ESRI.ArcGIS.esriSystem.EnvironmentManagerClass'.
[/Error]
by Anonymous User
Not applicable
by Anonymous User
Not applicable
Did you try using Activator.CreateInstance instead of "new"?
How To: Get the current user name and roles using a server object extension
WarrenMazoue
Thanks Kirk, that's pretty much what I needed to do.
I came across this other post
https://community.esri.com/thread/226087-unable-to-cast-comobject-to-environmentmanager-in-soe
which lead to a description of the bug here
BUG-000102447: The EnvironmentManager singleton object in the Serve..
by Anonymous User
Not applicable
It is my understanding that arcobjects singletons should always be instantiated via Activator.  This is a requirement of the "threads in isolation" design.
There may be singletons where using "new" works fine, but I've heard Activator should always work. (please someone chime in if this is not true)
