ArcGIS Feature Service Synchronization Errors
1759
06-21-2019 02:11 PM
BillHarvey1
We are getting errors in ArcGIS Server as below.   Can't seem to pin it down, but it seems we are getting duplicate replica/records (?) on the next synchronization where a replica can't be deleted in ArcGIS Server 10.5.   All there permissions are opened up and accessible to the ArcGIS config directories etc.   No permission problems which is about all I have been able to find as potential causes.
Does anyone have any ideas?  I am not sure I really understand these messages of the process it is going through.
WARNINGJun 21, 2019, 11:28:06 AMUnable to remove OHInspections_delta_upload_f4c7e10a-f325.geodatabase from server directory arcgisuploads. Failed to delete the item 'i615f017d-a37a-4b49-b527-9dd951b9cdcf'. Data item 'i615f017d-a37a-4b49-b527-9dd951b9cdcf' does not exist.
SEVEREJun 21, 2019, 11:28:06 AMFailed to delete the item 'i615f017d-a37a-4b49-b527-9dd951b9cdcf'. Data item 'i615f017d-a37a-4b49-b527-9dd951b9cdcf' does not exist.
WARNINGJun 21, 2019, 11:28:06 AMUnable to remove UGInspections_delta_upload_7598d9f8-136e.geodatabase from server directory arcgisuploads. Failed to delete the item 'i2fd86312-3af9-4f7d-a058-c0016d215060'. Data item 'i2fd86312-3af9-4f7d-a058-c0016d215060' does not exist.
SEVEREJun 21, 2019, 11:28:06 AMFailed to delete the item 'i2fd86312-3af9-4f7d-a058-c0016d215060'. Data item 'i2fd86312-3af9-4f7d-a058-c0016d215060' does not exist.
WARNINGJun 21, 2019, 11:28:06 AMUnable to remove OHInspections_delta_upload_9043515f-2c37.geodatabase from server directory arcgisuploads. Failed to delete the item 'i28c43b48-1412-4c83-9fad-1e2e13980368'. Data item 'i28c43b48-1412-4c83-9fad-1e2e13980368' does not exist.
SEVEREJun 21, 2019, 11:28:06 AMFailed to delete the item 'i28c43b48-1412-4c83-9fad-1e2e13980368'. Data item 'i28c43b48-1412-4c83-9fad-1e2e13980368' does not exist.
EricJackson1
We are seeing a similar error.  Did you find out what caused it?
