ArcGIS Server account permissions
3988
02-09-2014 02:35 AM
ShaharLevenson
Hello,
My ArcGIS Server 10.2.1 is running under a domain account for the server account. I've been asked by the system admin why does the server account need full-control permissions to folders such as <ArcGIS for Server installation directory>\framework or the directories folder. Couldn't it just be given a read/write permission instead?
Shahar.
nicogis
Certainly a permission superior to reading & writing is needed for these folders: http://technet.microsoft.com/en-us/library/bb727008.aspx (see Special Permissions for Files and Folders)
LeoDonahue
If you've chosen a local account, the local account and password must exist on each GIS server and be identical
Ask your system administrator why this works.  It's actually exploiting a security hole in the OS, my opinion.
I would say a local account is fine, but a domain account is easier to manage.  If you change the password on a local account, you have to change it on every machine you use it on.
Also, according to the link you provided Shahar, what permission requires this:
Start and stop processes that support the GIS server and services.
Doesn't the installation grant all the necessary permissions to a local account that you need?
ShaharLevenson
The installation process gave indeed the necessary permissions to the account.
My SysAdmin just asked me out of curiosity why the account needed such a high-level permission and I couldn't find an ESRI documentation which explains it.
I'm guessing the account needs to be able to delete files regardless of file permissions, but I'm not sure.
LeoDonahue
High level permissions granted to a local user account that is defined to a specific application installation location.  That seems fairly reasonable.
