Orthos in image service or map service?
2706
02-12-2014 02:02 PM
KennethCheng
Okay..I'm sure this has been asked before but here goes;
  • ArcServer 10.2 with no image extension, so I cannot publish directly from a mosaic dataset.
  • 20 ortho imagery in TIF format
At ArcGIS 10.0, I would create a MXD and simply add all 20 TIF images to my MXD and create a map service and then create a tiled cache.
[ATTACH=CONFIG]31385[/ATTACH]
Now at ArcGIS 10.21, I was trying something different....I created a Mosaic Raster Dataset using all 20 TIF images and then generated a tile cache from the Mosaic dataset.  After the tile generation, I can use the cache and create an image service.
[ATTACH=CONFIG]31384[/ATTACH]
I'm wondering which is better method is better in terms of performance?  Also, using a mosaic dataset appear to look better too.
