ArcGIS Server 10.7.1: What does the “Number of shared instances per machine” represent?
4707
7
10-04-2019 10:30 PM
JamalNUMAN
Legendary Contributor
For example, in the screenshot below, the “Number of shared instances per machine” is set to be 10. However, at particular time, as I checked the number of active ArcSoc, I found that they are 4 but NOT 10. Does this mean that the “Number of shared instances per machine” will never consume machine resources (RAM and CPU) unless requests (traffic) on services require using all the number of shared instances (10 in this case)?
Jamal Numan
MoginrajMohandas
Hi Jamal NUMAN‌ That does not sound right and should not be the case. This setting basically controls a special System service in ArcGIS Server. Can you pls navigate to https://<YourServerURL>/admin/services/System/DynamicMappingHost.MapServer?f=pjson and check the values for "minInstancesPerNode" and "maxInstancesPerNode". The values should be 10 and 10 in your case. One possibility is that it was updated from the administrative endpoint and has different values for min and max. If they are the same, try stopping and restarting this specific service(DynamicMappingHost.MapServer).
ThomasJones1
Hello Jamal,
The shared instances should always be running on each machine in your site. It's possible if you checked right away you might night not see the ArcSOC.exe immediately. As ArcGIS Server would take sometime to spin up the additional ArcSOC.exe after you update the shared instance pool settings.
You can run this follow command to count the number of ArcSOC.exe running on a machine.
tasklist | find "ArcSOC.exe" /c
Thomas.
JamalNUMAN
Thanks Thomas
In the screenshot below, the count of shared instances is 10 while the count of ArcSoc is 3
What could be the issue here?
Jamal Numan
MoginrajMohandas
JamalNUMAN
Thanks Moginraj.
Right.... stop\start the service below resolves the issue
https://localhost:6443/arcgis/admin/services/System/DynamicMappingHost.MapServer
Jamal Numan
MoginrajMohandas
Glad it was resolved. Curious as to how it got into that state. Any history on what kind of load was on the system, or any adminstrative actions being done. Basically, anything you can think of that was being done before the system got into this state? Any information would help.
JamalNUMAN
This issue occurred on a fresh test machine. Nothing specific has been implemented to the machine that might be thought as a reason for that state.
Jamal Numan
JamalNUMAN
But regarding the terminology, what is the difference between an instance and ArcSoc.exe? are they the same?
Jamal Numan
