arcgis pro crashes clicking on the parcel/shape
1170
12-04-2019 04:22 PM
RobertLogan
Clicking on the parcel/shape in arcgis pro crashes.
We have a sql server view that represents a join between two tables.
Table parcels represent parcel shapes and Table situs represent situs data about each parcel
View definition v_parcel_situs
CREATE VIEW [gis].[v_parcel_situs]
AS
SELECT p.ojbectId, p.shape, s.mailingAddress
FROM gis.PARCEL p
LEFT JOIN gis.situs s ON gis.PARCEL.APN = gis.GISwebd2.APN
GO
CREATE TABLE [gis].[situs](
[APN] [int] NULL,
[mailingAddress] [nvarchar](max) NULL
) ON [PRIMARY]
GO
Everything is fine, but if I change the sql server schema column definition of MailingAddress to [nvarchar](50) NULL then clicking on the parcel/shape in arcgis pro crashes.
[APN] [int] NULL,
[mailingAddress] [nvarchar](50) NULL
) ON [PRIMARY]
GO
RobertLogan
I know SQL Server, but I'm new to ESRI products.
The ArcGIS enterprise geodatabase has metadata on the columns of registered views and tables.dbo.SDE_column_registry
Solution:
1.  delete the view from arcgis pro,
2. re-create the view
3  re-register with arcgis
4. re-publish any services that display data from that view
It would be nice if there was some logging and/or indication somewhere of the issue.
George_Thompson
Esri Notable Contributor
I would work with technical support on this.
Does the mailingAddress field have records with more than 50 characters?
--- George T.
RobertLogan
Solution:
