ArcGIS Pro and web service and image service question
1643
8
12-12-2023 02:28 PM
GIS_Enjoyer
Hello developers,
Currently I can publish map service (url ends with "MapServer") to my Enterprise ArcGIS Server from ArcGIS Pro. But when I try to publish an image service in ArcGIS Pro, "Share as Web Layer" is grayed out if I don't sign in in Pro; if I do and use the default portal url (https://www.arcgis.com/home), it says I don't have permission.
So in order to publish it to my Enterprise ArcGIS Server (not ArcGIS Online), do I need to also install ArcGIS Portal?
Do I also need to install web adaptor?
Thank you and have a nice day!
Scott_Tansley
MVP Regular Contributor
The process you're using is to publish to ArcGIS Enterprise.  You need to publish to a standalone server: https://enterprise.arcgis.com/en/server/latest/publish-services/windows/service-publishing-in-arcgis...
Scott Tansley
https://www.linkedin.com/in/scotttansley/
MarceloMarques
Your ArcGIS Server must have a valid ArcGIS Image Server License.
Publish an image service—ArcGIS Pro | Documentation
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
GIS_Enjoyer
@Scott_Tansley @MarceloMarques
Thank you both for your information!
I successfully connected my ArcGIS Pro to my standalone ArcGIS Server. However, "Share as Web Layer" is still grayed out. Is it because ArcGIS Pro automatically detects that my ArcGIS Server doesn't have this "Image Server License"?
Scott_Tansley
The Share as a Web Layer is for ArcGIS Enterprise workflows, not standalone ArcGIS Server.  The weblink has links to the instructions for how to do this because it's a different workflow:
Map Services:  https://pro.arcgis.com/en/pro-app/latest/help/sharing/overview/publish-a-map-service.htm
Image Services:  https://pro.arcgis.com/en/pro-app/latest/help/sharing/overview/publish-an-image-service.htm
Scott Tansley
MarceloMarques
@GIS_Enjoyer  -  Follow the steps here - Publish an image service—ArcGIS Pro | Documentation
GIS_Enjoyer
Sorry I was getting Enterprise and standalone mixed up.
I am currently stuck on step 1 for Image Services because right click does not produce the "Publish" option. So is there a way to grant my Pro this privilege?
Or is there a way to do it with sd file like I did with map service?
Scott_Tansley
Terminology is 'everything' when trying to help someone through these pages.
Do you have Image Server License installed in your ArcGIS Server?  If not, that will explain it.
Scott Tansley
GIS_Enjoyer
Understood. Will be looking for the license then. Thank you both for this huge help!
