ArcGIS Print Service fails to start after upgrade to 10.9
1086
08-13-2021 10:53 AM
DaveAdams
I have just run an upgrade install on a single machine instance of ArcGIS Server from 10.7.1 to 10.9. All the services came back up fine and all the utilities services will stop/start as required with the exception of the printingTools. The error message is:
Service failed to start
Utilities.PrintingTools.GPServer: java.rmi.UnmarshalException: Error unmarshaling return header; nested exception is: java.net.SocketException: Connection reset
I tried a repair install but it made no difference.
The logs record:
Service containing process crashed for 'Utilities/PrintingTools.GPServer'. Please see if an error report was generated in 'C:\arcgisserver\logs\WIN-GC9U3PU6QUE\errorreports'. To send an error report to Esri, compose an e-mail to ArcGISErrorReport@esri.com and attach the error report file.
Any help would be greatly appreciated.
DaveAdams
After doing a clean install as opposed to an upgrade of 10.9 the print service started fine first time.
(uninstall of ArcGIS Server included removing all related folders, arcgis server user accounts etc)
