ArcGIS Powershell DSC configuration error
6692
7
02-11-2021 11:01 PM
AYUSHYADAV
Hello Team,
We are facing an issue while running the Invoke-ArcGISConfiguration command on Powershell DSC.
It gives an error:-
Start-DscConfiguration : The computer name was not specified and the configuration directory does not have any configuration files.
At C:\Program Files\WindowsPowerShell\Modules\ArcGIS\3.1.1\ArcGIS.psm1:233 char:131.
I have attached the screenshot also.
Please help us out.
ReeseFacendini
Esri Alum
In the JSON file that's used to pass in the parameters to the DSC (downloaded from GitHub), was that file opened and edited or just ran as is?
ReeseFacendini
Esri Alum
schulcp
Im having this same issue.
I don't see what the solution was to this.
The JSON Im using was downloaded from GitHub, Edited for my Env, and then run.
Im editing the 3 server JSON, but not the others.
Im wondering if I need to update the JSON for each server/role and then run the 3 Server JSON.
ReeseFacendini
Esri Alum
When downloading the JSON from GitHub, you need to edit the file and enter the information for your specific deployment.  The JSON files are templates only, not to be run as is.  Also make sure that the template matches the deployment pattern that you are after (single machine, multiple machine, highly available, etc.)
schulcp
Yes, l have done that. The Json file was completely edited for my environment
As noted in my original post
I still got the error
ALGIS
Hi @schulcp
Did you ever get a solution to this? I am having the same issue and I do not see one listed here.
Thanks
JoshHevenor1
Hi @schulcp ,  I'm seeing the same problem now.  You're post came up when I googled.  I'd try posting to the related github project, as they're pretty quick to respond.
@ReeseFacendini there is no solution here.
schulcp
I never did get a resolution. I called Esri support and walked through installing w/o powershell. I haven't circled back to see if Esri got the powershell install.
