ArcGIS License Manager 2021.1 Install : ArcGIS License Manager 2021.1
1018
12-09-2021 04:14 AM
DavidDugard
when installing this product I get
Please wait...
Uninstalling previous version...
Installing upgrade...
JRE libraries are missing or not compatible....
Exiting....
...ArcGIS License Manager 2021.1 installation is complete.
no files are installed
is there a solution for this?
JayantaPoddar
Are you working on Linux platform?
Please ensure the setup has permission to execute/read/write in appropriate folders.
A similar issue Web Adaptor install error : JRE libraries are miss... - Esri Community
Think Location
DavidDugard
that is the route that I'm taking - so far - no luck
ChristopherPawlyszyn
I would try making sure that the installation owner is able to write to the temp directory, another alternative may be to define the IATEMPDIR environment variable to redirect the installer to a known-working directory. Even though it isn't outlined in the docs, it applies to the License Manager installation in the same fashion it does for the other ArcGIS Enterprise components.
Monthly Linux Tip: Handling Temp Space in ArcGIS Server
https://www.esri.com/arcgis-blog/products/arcgis-enterprise/administration/monthly-linux-tip-handlin...
-- Chris Pawlyszyn
