ArcGIS for Server 10.1/Desktop Web Adaptor for IIS Issue
2190
07-02-2013 08:58 PM
JoseSousa
Just found out an odd behaviour of ArcGIS 10.1.
My install (Development Environment):
- ArcGIS for Server 10.1 SP1
- Authentication: Windows (Web Tier)
- Web Adaptor for IIS (administrative access enabled)
I have tried to setup the GIS Server admin connection in ArcGIS for Desktop using the Web Adaptor URL and noticed that it rejects that URL and replaces for the GIS Server site URL running on port 6080.
Monitoring the requests that have been made I have noticed that ArcGIS for Desktop attempts to use the Web Adaptor URL, verifies that it has SSL enabled (???) and tries to invoke the generateToken method using HTTPS which is obviously denied since this is a dev environment and does not have the certificate installed.
I actually haven't enabled SSL on the Web Adaptor. It just inherited the Default Web Site properties ... which did support HTTPS.
Because he couldn't connect using HTTPS, ArcGIS for Desktop changes the request to the AGS Server site running on port 6080 and verifies that it works and ignores my setting. This means that anyone using that connection will go directly to the AGS site instead of the Web Adaptor.
I have removed the SSL support on the Web Adaptor and ArcGIS for Desktop allowed me to change the connection ... finally. Without closing ArcGIS for Desktop I just enabled again the SSL and noticed that ArcGIS for Desktop allowed me to change it again ... odd. I have closed ArcGIS for Desktop and opened it again and tried to change the connection and it started working as previously and ignoring my settings.
Not sure if this is an intended behaviour but is quite odd and took some time to figure out. Maybe ArcGIS for Desktop shouldn't be accepting the connection in first place if it considers it invalid? Instead of trying to guess and change it to something that I don't want and without telling me that an issue occured?
It is a bit odd testing whether the Web Adaptor supports SSL or not and if it does assume that the GIS server site also supports ... these are separe components ...
Hope 10.2 does not have similar behaviour.
Cheers,
Jose
Because it is a development environment I haven't configured an SSL certificate on the AGS server site.
BubbaHey
There are a few bugs on this.  Try using GIS tier instead of web tier authentication. Web adaptor does support SSL, see:
Enabling SSL on ArcGIS Server when accessed through the ArcGIS Web Adaptor
http://resources.arcgis.com/en/help/main/10.1/index.html#/Enabling_SSL_on_ArcGIS_Server_when_accesse...
Bugs:
Bug NIM-083483
http://support.esri.com/en/bugs/nimbus/TklNMDgzNDgz
Unable to create administrative connection in ArcCatalog through a web adaptor when the ArcGIS Server host name is the same as the web adaptor folder name.
Bug NIM-088319
http://support.esri.com/en/bugs/nimbus/TklNMDg4MzE5
dmin and publisher connection cannot be made from ArcGIS Desktop via the web adaptor if the website hosting the web adaptor has HTTPS site binding.
There are other bugs too, just can't find them right now
JoseSousa
Hi Bubba,
Glad to see that the bugs are already acknowledged as I have been finding some of them quite often and they are quite difficult to trace. I just don't have the time to create a thread for each issue as it is time consuming.
Thanks for pointing me to those links.
Cheers,
Jose
BubbaHey
Welcome! Not sure if these are fixed in 10.2 though
