Can I to Keep Alive a SOE?
3025
07-04-2013 01:31 AM
MassimilianoGeppi
Hi
I've notice that each SOE is shutdown if its arcgis service isn't used for a long time.
But I need to build a SOE to check every minute if a record in a table is changed.
Is there a workaround to keep alive a SOE and ensure that it continues to run?
I thought to create a thread to call the SOE through a REST method every minute,
but i don't know if this is a good practice or if there is another solution
designed direcly by "esri".
thank you in advance.
Max
RichardWatson
See Recycling:
http://resources.arcgis.com/en/help/main/10.1/index.html#/Tuning_and_configuring_services/0154000003...
Note that you can also specify a minimum number of instances when you create the map service.
nicogis
what's the dbms?
