ArcGIS Enterprise - Portal - Grouped Layers
431
01-10-2019 12:38 AM
FGGEms
Hello GeoNet community,
is it possible to make grouped layers in the map application of ArcGIS-Enterprise Portal? I need three levels of grouped layers:
- Layer
   -> First sublayer
        -> second sublayer
             -> third sublayer
Is it possible to implemend lines with two different colors:
Kind regards
Stephanie
DerekLaw
Esri Esteemed Contributor
Hi FGG Ems,
When you say "map application of ArcGIS-Enterprise Portal", I believe you're referring to the Portal Map Viewer application. With this in mind,
Q1. ... is it possible to make grouped layers in the map application of ArcGIS-Enterprise Portal?
A1. Not yet, but this is on the Dev roadmap and coming in a future release. Please see this ArcGIS Idea,
Group layers for ArcGIS online
Q2. Is it possible to implemend lines with two different colors:
A2. Not at this time. Please vote for the enhancement, https://community.esri.com/ideas/14241
Hope this helps,
