A generic tool to convert multiple mdf files to gdb,
17744
38
04-09-2017 11:20 AM
JamalNUMAN
Legendary Contributor
To enjoy multiusers editing environment, our data is stored in mdf files (enterprise). However, when it comes to publishing, we convert the mdf to gdb in order to gain some performance as the services that read from gdb are much faster than those read from mdf. We are wondering if there is a generic tool that can convert multiple mdf files to gdb.
Thank you
Best
Jamal
Jamal Numan
abdullahqasrawi
Hi Ahmed thanks for your input, its working fine with me but the tool did not transfer Global id field
JoshuaBixby
MVP Esteemed Contributor
AhmadSALEH1
Your right, but the issue is that   Preserve Global ID works  only  in ArcGIS Pro. What do you think?
JoshuaBixby
Ah, yes, you are using ArcGIS Desktop/ArcMap.  I believe Preserved Global IDs was introduced at Pro 1.2.  Is using ArcGIS Pro an option?  Not surprisingly, the What's New in ArcGIS 10.6 is pretty anemic and doesn't mention anything about preserving global IDs.  I wish I had a better answer for you; unfortunately, I think we are going to see more and more of this over the next couple years as the development/resource gap grows between ArcMap and Pro.
JamalNUMAN
Hi Ahmad,
As we have currently two tools to convert mdf to gdb depending on whether the gdb is published or not, is there any chance to combine these two tools into one such that we can have one generic tool that convert mdf to gdb in all cases
Best
Jamal
Jamal Numan
AhmadSALEH1
Yes I think I can do that, I will send it over when its ready.
AhmadSALEH1
Jamal,
Here you go. The tool will do the following:
1- stop the selected services. (optional, if you  want to run the tool without stopping and starting the service leave the services unselected)
2- delete the old gdb's.
3- copy the sde data to the destination folder.
4-start the services again.
let me know if you had any issues running the tool.
Ahmad
abdullahqasrawi
Hi Ahmad
Perfect work, it is working fine with me.
JamalNUMAN
Fantastic Ahmad. You deserve an award for developing this generic tool to convert multiple mdf to gdb
Jamal Numan
AhmadSALEH1
glad it worked!
