Hello GeoNet,
I had an error message on my Portal page saying that "The Portal for ArcGIS licenses may be expired."
It was expired when I checked the keycodes file at C:\Program Files\ESRI\License10.6\sysgen
But why would it have a expiration date when the license says perpetual under My Esri account?
The problem is fixed after putting a new authorization code at the Portal for ArcGIS Level 2.
Does it mean I need to re-generate the code and re-authorize it every year even though the ArcGIS Enterprise license says perpetual?
Thank you,
Emily
Hi Emily,
I believe the behavior your are seeing is outlined and explained at the resource link below:
https://support.esri.com/en/Technical-Article/000020991
Hope this helps!
Hi Emily,
If you contact your Customer Service representative, they should be able to help out.
Hilary
Hi Hilary,
Thank you for your reply. Yes, I called them and they were able to help me to generate a new code to put in. But I still don't understand why I need to do that and does it mean I'd need to do that every year?
Thanks again,
Emily
Hi Emily,
Hope this helps!
Thank you Elizabeth.
