WebGISDR Backup fails with "Failed to generate token for Portal for ArcGIS. Verify that the credentials you entered are correct"
27151
42
02-26-2021 04:09 AM
MHahn
The Portal Installation has been updated from 10.7.1 to 10.8.1.
I am not sure if webgisdr worked after update. But now I got the following error in the webgisdr log:
2021-02-26 12:53:32 ERROR [main] com.esri.arcgis.webgis.client.WebGISDR - Failed to generate token for Portal for ArcGIS. Verify that the credentials you entered are correct. Check the WebGIS DR utility logs and the Portal for ArcGIS logs for more information.
 I double checked the password 🙂
In the logback.xml in the webgis directory I set the loglevel to DEBUG. After that I saw the following exception.
Caused by: java.lang.RuntimeException: The response returned HTTP status code 404. Requested URL: https://[fqdn of internal portal url]:7443/arcgis/portaladmin/sharing/rest/generateToken
I got the same response in a browser.
The url to the generateToken endpoint is:
https://[fqdn of internal portal url]:7443/arcgis/sharing/rest/generateToken
without the portaladmin directory
Did I miss something?
Thanks!
2 Solutions
JonathanQuinn
Esri Notable Contributor
This is a bug:
BUG-000135171 If the portal hostname changes, the DR tool fails to run with the error "Failed to generate token for Portal for ArcGIS"
KrystalPhaneuf2
@JonathanQuinn
We are attempting this in our development environment today.  Just want to clarify the name should change in the Portal Admin > Machines > Machine name.   We have installed the Enterprise Sites 3 patch that was supposed to correct the behavior. We plan to:
Update the C:\Program Files\ArcGIS\Portal\framework\etc\hostname.properties file to the shortname
Restart the Portal
check the admin page for shortname
Change the short name back to the FQDN in the hostname.properties file
Restart Portal
Check admin name again for FQDN
Retry webgisdr
George_Thompson
I would reach out to Esri Technical Support on this issue.
--- George T.
JakeSkinner
Esri Esteemed Contributor
Hi @MHahn ,
I would try and recreate the .properties file and then re-execute the webgisdr utility.
by Anonymous User
Not applicable
Hello Matthias
Have you tried Web Adapter address or LB address?
Regards,
Bing
JonathanQuinn
This is a bug:
MHahn
The german support team helped me out 👍
There is a (very unsupported) workaround for this bug.
Sign in to the Portal DB (gwdb) and update the Admin-URL of the Portal. (remove the directory portaldmin)
Sander
Hello Matthias, can you share a litlle bit more detail. I am not yet able to find the table in which I need to change (remove) this value.
Thanks in advance
Sander
JonathanQuinn
@Sander my suggestion is to go through a more "supported" approach following my instructions here.
If you have updated the hostname.properties file, update the hostname there instead.
NoorSyazanaMdYusof
Hi @MHahn , can I know how to sign in and access this gwdb?
EricAnderson_DHS
Hi @JonathanQuinn
We're also hitting this exact issue at 10.8.1, but our Portal hostname has never changed. This is currently a HA Portal and the primary Portal admin URL shows as :7443/arcgis/portaladmin, while the standby shows as :7443/arcgis (checking from webadaptor.domain/webadaptor/portaladmin/machines page).
Is there any *supported* way to update the admin URL for our primary machine and remove the /portaladmin reference?
