Vector Tile Service (VTS) supported formats - Ordnance Survey Data Hub
2362
6
06-10-2021 07:18 AM
ChrisBuckmaster2
I am trying to add a Vector Tile Service from Ordnance Survey's Data Hub which uses the PBF format to provide tiles and is formatted in the following:-
https://api.os.uk/maps/vector/v1/vts/tile/{z}/{y}/{x}.pbf?srs=27700&key=
I have tried to add this into a new map using ArcGIS Portal 10.6 but am just getting a blank screen.
Can I confirm that this tile format is supported, and if anyone has successfully managed to add any VTS tiles from Ordnance Survey into a Portal map?
Thanks
StuartMoore
did you ever get it working, we are trying the same sort of thing i can add the data into a arcgis online map and it shows okay but as soon as you open it in a arcgis web appbuilding you get a blank basemap
Stu
HalilSiddique
@StuartMoore  How did you get it working on ArcGIS Online, all i get is a blank map.
StuartMoore
@HalilSiddique if you reset the scales in your app the map will display
StuartMoore
this is the url we use: https://api.os.uk/maps/raster/v1/wmts?key=
so its the map service rather than the vector service
HalilSiddique
ok, thanks, i was hoping to use the vector service, i'll ask OS if it is possible.
HelenWhiteley_tfl
I am also interested in knowing if you ever got this working in ArcGIS Portal. Thanks.
