Map Viewer properties pane is blank (for Styles, Filter, Configure Pop-ups, Configure Fields, & Labels).
4936
8
04-21-2023 11:46 AM
Matt-Goodman
In ArcGIS Enterprise Portal, when configuring a web map using the Map Viewer (not 'Classic'), the properties pane remains blank for any/all layers that I try to configure (see attached screenshot).
The blank properties panel occurs for...
  • Styles
  • Filter
  • Configure Pop-ups
  • Configure Fields
  • Labels
This issue is occuring for me in Edge as well as Chrome. I worked on some troubleshooting with my IT staff, to no avail. We tried:
  • Cleared browser cache.
  • Adding our portal URL to Chrome's 'Allow to share insecure content' setting.
  • Changed network security profile to 'admin', restarted computer.
MichaelJenkins
Esri has just confirmed that the latest security patch for AGE 10.9.1 introduced a bug that causes what we are seeing.  You must uninstall the patch or wait for them to release a hotfix.
It's not us, it's them  🙂
https://support.esri.com/en-us/patches-updates/2023/portal-for-arcgis-security-2023-update-1-patch-8...
GISP
DevonReed
We are also having this issue.
MichaelJenkins
M-G, did you happen to apply security updates before this problem began?  As Devon said, we are seeing the same issue and the only change we've made recently is to apply security updates.
My browser is showing 404 errors for some of the JSAPI4 items, which I am guessing is causing the problem.  The files are on the sever, but the URL to them is throwing a 404. Are you seeing this too?
GISP
Matt-Goodman
Yes, I'm seeing the same errors (see attached image).  "Failed to load" / "Refused to execute script" / "scriptError" for:
  • piChart.js
  • flow.js
Also, possibly unrelated, two failure-to-load errors for
  • ".../compat.module.js.map"
  • ".../MapViewer.js.map"
Matt-Goodman
In fact, our IT did apply changes to my security profile shortly before this was noticed, and that was my first suspect. But I worked through significant 'troubleshooting' with them, including reverting my security profile to 'admin', to no avail. Our IT folks don't think it was caused by the change to security settings (naturally).
MichaelJenkins
Interesting.  I just confirmed this is an issue or two of our Portals but not on two other Portals.  By security updates I mean the ArcGIS Portal / Server patches.
GISP
Matt-Goodman
I just confirmed that our IT did recently apply security update patches immediately before this issue presented (see attached for details).
  • Portal for ArcGIS 10.9.1 Log4j Patch B
  • Portal for ArcGIS 10.9.1 Security 2022 Update 1 Patch
  • Portal for ArcGIS 10.9.1 QuickCapture Security Patch
  • Portal for ArcGIS 10.9.1 Security 2022 Update 2 Patch B
  • Portal for ArcGIS 10.9.1 Enterprise Sites Footer Display Patch
  • Portal for ArcGIS 10.9.1 Security 2023 Update 1 Patch
Sounds like a likely culprit...
MichaelJenkins
GISP
Travb
We've now noticed this across all of our Enterprise environments.
In map viewer, once the user clicks on styles this is where the same behaviour begins for us.
Any ESRI updates on when the hotfix is coming?
