The Layer xyz is not responding / cannot be added to the map
3276
9
05-14-2018 03:56 AM
LR
I can't add any hosted layer to a map - all I get is the error above. I guess it has something to do with REST, because when I validate the server (https://[MACHINENAME].local/portal/portaladmin/federation/servers/), I get a "success" status but also the message that "the ArcGIS-Server-Services-URL 'https://[MACHINENAME].local:2443/arcgis/datastore' can't be checked for 'https://[MACHINENAME].local:2443/arcgis/datastore/rest/info'." The messages are in German, the rest of the page is in English, despite setting the language prefs in Portal to English.
SSL is enabled, and I restarted the server too. Adding local files to a map works however.
JakeSkinner
Esri Esteemed Contributor
Hi LR,
Are you able to access the Hosted services in the REST Services Directory.  Ex:
https://<server.domain.com:6443>/arcgis/rest/services/hosted
LR
I can - viewing the footprints also works (pushpin on the map in the right place).
JakeSkinner
Have you tried another client, such as ArcMap or ArcGIS Pro, to view the hosted feature services?  If you can view them there, this would indicate an issue with Portal.  If you cannot, it's mostly likely something corrupt with the feature services.
JonathanQuinn
Esri Notable Contributor
Is this the exact error message you get? If so, your federation URLs are incorrect. You register the Data Store with Server going through https://<machine>.local:2443/arcgis/datastore, but you federate Portal and Server using https://<machine>.local:6443/arcgis, (at least for the admin URL).. Can you check the federated Servers and verify what URL you used for the services and admin URLs?
LR
Service
Administration
https://[MACHINENAME].local:6443/arcgis/
When I set up Datastore I used https://localhost:6443/ as GIS Server URL, can this be a problem? Unfortunately there's no apparent way to change the URL, it's just telling me it's configured!
JonathanQuinn
Yes, that's definitely the problem. The services URL should be the URL that clients will use to connect to services, for example:
https://<machine>.local/server
You should unfederate and refederate using the correct URL.
LR
The Datastore URL wasn't the problem. I even tried the correct URLs (.local:6443/arcgis/ and .local/arcgis/) before - the actual problem is that the layers already in the Datastore can't be loaded anymore after an URL change.
Let's see what doesn't work next..
JonathanQuinn
The problem is that once you configure the site incorrectly, even editing the URLs in the Sharing API won't fix the existing services in the site. You need to update those manually. Refederate using the correct URL and then publish a new service and see if it works.
