Stacking labels from within a single attribute field
1491
02-17-2012 04:28 AM
JamesSiddle
Hi
Its been touched on in some of the archived posts, but I can't seem to get this to work.
I want to label some points using the contents of a single text field. I'm familiar with using vbnewline for doing this with seperate fields, its quite simple. But i'd like to be able to stack labels based on inserting a symbol of some description (e.g.  '/' or '*') into the single field
E.g. :
"Started 2010 / under construction / still waiting on management approval" to look like this:
Started 2010
under construction
still waiting management approval
I found the following vbscript example in an archived thread:
Function FindLabel ( [myField] )
FindLabel = Replace( [myField], "/", vbCrLf)
End Function
But the expression editor says that using the Replace command is incorrect.
Help?
Thanks
AlexeyTereshenkov
I've just tested using the script code you've posted and it works fine. I use ArcGIS 10 SP3. What's about you?
The workflow I use is: Layer Properties > check the Label features in this layer check box. Click the Expression button > check the Advanced check box > copy the code into the Expression text box. This is it. I guess you have not checked the Advanced option, so the parser cannot be used. Also make sure that the VBScript is used for Parser: option.
Function FindLabel ( [FieldName] )
FindLabel = Replace( [FieldName] , "/", vbCrLf)
End Function
JamesSiddle
thanks for your reply
i've tried running it again, but made sure all of my fields in the column had something in them, and it worked fine. I think it was coming up with the error because there were some null values.
Thanks
AlexeyTereshenkov
Awesome, James, glad it played out well.
MarkBoucher
Honored Contributor
I recently ran across a label script that wraps text: http://arcscripts.esri.com/details.asp?dbid=12607
It looks like it counts characters and finds spaces so that the wrap starts in a logical place. You can adjust the length of the wrap. If your data have a typical length and are in one field, this might work. If your data have variable lengths, what you have would likely work better.
