How to Scale up the Size of the text in the Annotation Layer.
2115
02-26-2012 06:46 PM
Kin_LunYuen
?Dear All,
I found a problem that a annotation layer data is too SMALL.  We can not read the text label at the scale that we expected.
As it is constantly obtained from the other parties, we don't wanna change its data & content.
Is there anyway to modified the size of the Text in the ArcMap Setting (mxd)?
I find a way to change its Color, but is there a way for scaling up the text size little bit 120%?
I am using ArcMap 10.
Thank you very much
Regards
EricLun
AlexeyTereshenkov
Hi Eric,
If I got you right, you want to change the size of the text in your annotation layer without actually modifying the underlying attribute table field (i.e., FontSize field). This can be done within the symbology settings of your annotation layer in ArcMap. Right-click the layer > Properties > Symbology tab > Symbol Substitution > Substitute individual symbols in the symbol selection option.
Symbol Substitution is layer-based functionality for temporarily changing the symbology of an annotation layer in ArcMap and these settings are stored within the .mxd document, but you can export a layer file (.lyr) which will preserve the symbol substitution settings, too.
