SSL errors because /self returns portHostName with port 7080
535
08-23-2021 11:59 AM
JonSwoveland
Hi, I've got a stand-alone Portal installed in a test environment to use for content management.
I have not installed a WebAdapator because we don't have the need for one in this deployment.
The problem we're running into is the portalHostName property returned from the /self endpoint includes the port 7080, not 7443.
The Portal is configured to allow traffic over HTTPS only.
I've tried setting the WebContextUrl to https://......:7443/arcgis but this made no difference.
Anybody have any ideas how to fix this?
Thanks!
JonathanQuinn
Esri Notable Contributor
What you're seeing can be considered a bug, so you can contact Support to have it logged. Normally, the environment will at least set up a Web Adaptor for the front-end. The Web Context URL can only be set to 443.
There's no way to update the hostname, you'll need to set up something in front of Portal.
